Aktuelle Zeit: 15 Jan 2025 22:50
Ein neues Thema erstellen Auf das Thema antworten  [ 12252 Beiträge ]  Gehe zu Seite Vorherige  1 ... 250, 251, 252, 253, 254, 255, 256 ... 817  Nächste
BeitragVerfasst: 12 Jan 2011 09:16
felix__w hat geschrieben:
Meine Mutter hat diese Woche erfahren, dass sie Brustkrebs hat und sie wird morgen operiert :(
Felix
da drück ich Euch alle verfügbaren Daumen!!! :gut
BeitragVerfasst: 12 Jan 2011 09:26
Verdammt, sind das viele... :chris76
Microsoft® Visual C#® Default Key Bindings
Editing
Edit.CollapseTo-
Definitions
CTRL + M, O Collapses declaration bodies to
provide a high-level view of the
types and members in the source
file.
Edit.HideSelection CTRL + M, CTRL + H Collapses current selection to an
outlining region.
Edit.ToggleAll-
Outlining
CTRL + M, L Toggles all previously collapsed
outlining regions between
collapsed and expanded states.
Edit.Toggle-
OutliningExpansion
CTRL + M, M Toggles the currently selected
collapsed region between the
collapsed and expanded state.
Edit.StopOutlining CTRL + M, P Removes all outlining information
from the whole document.
Edit.Comment-
Selection
CTRL + K, C or
CTRL + E, C
Inserts // at the beginning of the
current line or every line of the
current selection.
Edit.Uncomment-
Selection
CTRL + K, U or
CTRL + E, U
Removes the // at the beginning of
the current line or every line of the
current selection.
Edit.Format-
Document
CTRL + K, D or
CTRL + E, D
Formats the current document
according to the indentation and
code formatting settings specified
on the Formatting pane under
Tools | Options | Text Editor | C#.
Edit.Format-
Selection
CTRL + K, F or
CTRL + E, F
Formats the current selection
Edit.InsertSnippet CTRL + K, X Displays the Code Snippet Picker.
The selected code snippet will be
inserted at the caret position.
Edit.SurroundWith CTRL + K, S Displays the Code Snippet Picker.
wrapped around the selected text.
Edit.InvokeSnippet-
FromShortcut
TAB Inserts the expanded code snippet
from the shortcut name.
Edit.Cycle-
ClipboardRing
CTRL + SHIFT + V Pastes text from the Clipboard ring
to the caret location in the file.
Subsequent use of the shortcut key
iterates through the items in the
Clipboard ring.
Edit.Replace CTRL + H Displays the replace options in the
Quick Replace tab of the Find and
Replace dialog box.
Edit.ReplaceInFiles CTRL + SHIFT + H Displays the replace options on the
Replace in Files tab of the Find
and Replace dialog box.
View.Show-
SmartTag
CTRL + PERIOD (.)
or SHIFT + ALT +
F10
Displays the available options on
the Smart Tag menu.
Edit.Toggle-
CompletionMode
CTRL + ALT +
SPACEBAR
Toggles between suggestion mode
(all commit characters except for
tab leave entered text as-is, tab
chooses a completion item in the
list) and completion mode.
Edit.<Direction>
ExtendColumn
SHIFT + ALT +
<ARROW KEY>
Creates a box selection instead of a
stream selection.
File
File.NewProject CTRL + SHIFT + N Displays the New Project dialog
box.
File.OpenProject CTRL + SHIFT + O Displays the Open Project dialog
box, where existing projects can be
added to the solution.
Project.AddClass SHIFT + ALT + C Displays the Add New Item dialog
box and selects Class template as
default.
Project.Add-
ExistingItem
SHIFT + ALT + A Displays the Add Existing Item
dialog box, where existing files can
be added to the current project.
Project.Add-
NewItem
CTRL + SHIFT + A Displays the Add New Item dialog
box, where a new file can be added
Window.ShowEz-
MDIFileList
CTRL + ALT +
DOWN ARROW
Displays a pop-up listing of all open
documents.
IntelliSense
Edit.CompleteWord CTRL + SPACEBAR
or CTRL + K, W
Completes the current word in the
completion list.
Edit.ListMembers CTRL + J or
CTRL + K, L
Invokes the IntelliSense®
completion list.
Edit.QuickInfo CTRL + K, I Displays the complete declaration
for the specified identifier in your
code in a Quick Info tooltip.
Edit.ParameterInfo CTRL + SHIFT +
SPACEBAR or
CTRL K, P
Displays the name, number, and
type of parameters required for the
specified method.
Make Completion
List Transparent
CTRL Causes a visible completion list to
become transparent.
Navigation
Edit.NavigateTo CTRL + COMMA (,) Displays the NavigateTo window,
which allows quick navigation to
files, types, and members. The word
at the caret seeds the search.
Edit.FindAll-
References
SHIFT + F12 or
CTRL + K, R
Displays a list of all references for
the symbol selected.
Edit.GoToBrace CTRL + ] Moves the caret location to the
matching brace in the source file.
Edit.GoToDefinition F12 Navigates to the declaration for the
selected symbol in code.
Edit.GoToNext-
Location
F8 Moves the caret to the next item,
such as a task in the Task List
window or a search match in the
Find Results window. Subsequent
invocations will move to the next
item in the list.
Edit.Incremental-
Search
CTRL + I Activates incremental search. If
incremental search is on, but no
input is passed, the previous search
query is used. If search input has
been found, next invocation
searches for the next occurrence of
the input text.
Edit.FindNext,
Edit.FindPrevious
F3 and SHIFT + F3 Searches again for the last search
pattern in the direction specified.
Edit.FindNext-
Selected,
Edit.FindPrevious-
Selected
CTRL + F3 and
CTRL + SHIFT + F3
Sets the search pattern to the
selected text, then search in the
View.Forward-
BrowseContext
CTRL + SHIFT + 7 Moves to the next item called in
code in the current file. Uses the Go
To Definition navigation stack.
View.PopBrowse-
Context
CTRL + SHIFT + 8 Moves to the previous item called in
View.Navigate-
Backward
CTRL + HYPHEN (-) Moves to the previously browsed
line of code.
View.Navigate-
Forward
CTRL + SHIFT +
HYPHEN (-)
Moves to the next browsed line of
code.
Edit.FindInFiles CTRL + SHIFT + F Displays the Find in Files tab of the
Find and Replace dialog box.
Edit.FindSymbol ALT + F12 Displays the Find Symbol pane of
the Find and Replace dialog box.
View.ViewCode F7 Displays the selected item in Code
view of the editor.
View.ViewDesigner,
View.ViewMarkup
SHIFT + F7 Switches between Design and
Source views for the current
document
Window.MoveTo-
NavigationBar
CTRL + F2 Moves focus to the drop-down bar
located at the top of the editor
when the editor is in Code view or
Server Code view.
Edit.Find CTRL + F Displays the Find Quick tab of the
Edit.GoTo CTRL + G Displays the Go to Line dialog box.
Edit.GoToFind-
Combo
CTRL + / Moves focus to the Find/Command
box on the Standard toolbar.
EditorContext-
Menus.Code-
Window.ViewCall-
Hierarchy
CTRL + K, T Brings focus to the Call Hierarchy
window using the member at the
caret as a top-level node.
Edit.NextHighlightedReference,
Edit.PreviousHighlightedReference
CTRL + SHIFT +
DOWN ARROW
and CTRL + SHIFT
+ UP ARROW
Moves the caret to the next or
previous highlighted identifier
matching the current one.
© 2009 Microsoft Corporation. All rights reserved. Microsoft,
IntelliSense, Visual C#, Visual Studio, and the Visual Studio
logos are trademarks of the Microsoft group of companies.
All other trademarks are the property of their
respective owners.
Refactoring
CodeRush Xpress is a free plug-in from Developer Express
Inc., in partnership with Microsoft. CodeRush Xpress
supports more than 50 refactoring features. See www.
devexpress.com/Products/Visual_Studio_Add-in/
CodeRushX/ for more information.
Refactor.-
EncapsulateField
CTRL + R, E Displays the Encapsulate Field
dialog box, which allows creation
of a property from an existing field
and updates all references to use
the new property.
Refactor.Extract-
Interface
CTRL + R, I Displays the Extract Interface
of a new interface with members
derived from an existing class,
struct, or interface.
Refactor.Extract-
Method
CTRL + R, M Displays the Extract Method dialog
box, which allows creation of a new
method from the selected code.
Refactor.Remove-
Parameters
CTRL + R, V Displays the Remove Parameters
dialog box, which allows removal of
parameters from methods, indexers,
or delegates by changing the
declaration at any locations where
the member is called.
Refactor.Rename CTRL + R, R or F2 Displays the Rename dialog
box, which allows renaming all
references for an identifier.
Refactor.Reorder-
Parameters
CTRL + R, O Displays the Reorder Parameters
dialog box, which allows changes
to the order of the parameters for
methods, indexers, and delegates.
Refactor! CTRL +
BACKQUOTE (`)
Invokes available Developer Express
Inc. refactorings when it is installed.
Build
Build.BuildSolution F6 or
CTRL+SHIFT+B
Builds all the projects in
the solution.
Build.BuildSelection SHIFT+F6 Builds the selected project
and its dependencies.
Note: You can choose to use these key bindings from the Visual
C# Development Settings. To change these settings, go to Tools
| Import and Export Settings... and select Reset All Settings.
Then select Visual C# Development Settings. You could also
import only the key bindings by selecting Import Selected
Environment Settings instead of Reset All Settings. To
customize individual key bindings, go to Tools | Options |
Environment | Keyboard.
Debugging
Debug.Autos CTRL+D, A Displays the Autos window, which
displays variables used in the current line
of code and the preceding line of code.
Debug.CallStack CTRL+D, C Displays the Call Stack window,
which displays a list of all active
methods or stack frames for the
current thread of execution.
Debug.Immediate CTRL+D, I Displays the Immediate window,
where expressions can be evaluated.
Debug.Locals CTRL+D, L Displays the Locals window, which
displays the local variables and their
values for each method in the
current stack frame.
Debug.QuickWatch CTRL+D, Q Displays the QuickWatch dialog
box that has the current value of
the selected expression.
Debug.Start F5 Launches the application under the
debugger based on the settings from
the startup project. When in Break
mode, invoking this command will run
the application until the next breakpoint.
Debug.Start-
WithoutDebugging
CTRL+F5 Launches the application without
invoking the debugger.
Debug.StepInto F11 Executes code one statement at a
time, following execution into
method calls.
Debug.Step-
IntoSpecific
SHIFT+ALT+F11 Prompts to select which sub
expression to step into, regardless
of the tools options setting for
skipping properties and operators.
Debug.StepOut SHIFT+F11 Executes the remaining lines of a
method in which the current
execution point is located.
Debug.StepOver F10 Executes the next line of code, but
does not follow execution through
any method calls.
Debug.Stop-
Debugging
SHIFT+F5 Stops running the current
application under the debugger.
Debug.Toggle-
Breakpoint
F9 Sets or removes a breakpoint at the
current line.
Debug.Watch CTRL+D, W Displays the Watch window, which
displays the values of selected
variables or watch expressions.
Debug.Enable-
Breakpoint
CTRL+F9 Toggles the breakpoint between
disabled and enabled.
Make Datatip
Transparent
[CTRL] Causes a visible datatip to become
transparent.
Test.RunTestsIn-
CurrentContext
CTRL+R, T Runs the unit test containing
the caret.
Test.RunAllTests-
InSolution
CTRL+R, A Runs all of the unit tests in
the solution.
Window
View.ClassView CTRL + W, C Displays the Class View window.
View.Code-
DefinitionWindow
CTRL + W, D Displays the Code Definition
window.
View.ErrorList CTRL + W, E Displays the Error List window.
View.ObjectBrowser CTRL + W, J Displays the Object Browser.
View.Output CTRL + W, O Displays the Output window, where
status messages can be viewed at
run time.
View.Properties-
Window
CTRL + W, P Displays the Properties window,
which lists the design-time
properties and events for the
currently selected item.
View.Solution-
Explorer
CTRL + W, S Displays Solution Explorer, which
lists the projects and files in the
current solution.
View.TaskList CTRL + W, T Displays the Task List window,
which displays custom tasks,
comments, shortcuts, warnings, and
error messages.
View.Toolbox CTRL + W, X Displays the Toolbox, which
contains controls that can be
included or used with your code.
View.ServerExplorer CTRL + W, L Displays Server Explorer, which lets
you view and manipulate database
servers, event logs, message queues,
Web services, and other operating
system services.
Window.CloseTool-
Window
SHIFT + ESC Closes the current tool window.
Data.ShowData-
Sources
SHIFT + ALT + D Displays the Data Sources window.
Window.Close-
DocumentWindow
CTRL + F4 Closes the current tab.
Window.NextDocumentWindowNav
CTRL + TAB Displays the IDE Navigator, with
the first document window selected.
View.CallHierarchy CTRL + W, K Displays the Call Hierarchy
window, which lists callers and
callees for a given member.
View.ZoomIn,
View.ZoomOut
CTRL + SHIFT +
PERIOD (.) and
CTRL + SHIFT +
COMMA (,)
Increases (>) or decreases (<) the
size of contents in the editor.
BeitragVerfasst: 12 Jan 2011 09:34
Gab`s dafür nicht mal nen Fred als Zwischenablage? :mrgreen:
BeitragVerfasst: 12 Jan 2011 10:13
Felix
Ich wünsch Deiner Mutter alles Gute und Euch, als ganzer Familie, viel Kraft um diese Zeit durchzustehen!
BeitragVerfasst: 12 Jan 2011 10:15
Felix
Oh! Ich hab`s grad erst gelesen! Von mir auch alles, alles erdenklich Gute und viel Kraft für die kommende Zeit! :gut
Felix
Alles Gute! Ich glaube die Heilungschancen sind ja mittlerweile ganz gut.
BeitragVerfasst: 12 Jan 2011 10:19
Felix
Alles Gute! :gut
BeitragVerfasst: 12 Jan 2011 10:21
Felix
Ich drück die Daumen!
BeitragVerfasst: 12 Jan 2011 10:43
Felix
+2
BeitragVerfasst: 12 Jan 2011 10:55
Felix
+2
+2!
:kuss
BeitragVerfasst: 12 Jan 2011 11:00
Felix
+2
+2!
:kuss
+3!!
Das relativiert dann mal wieder andere Problemchen ganz schnell! :(
BeitragVerfasst: 12 Jan 2011 11:02
triaking hat geschrieben:
das denke ich hier im Forum eigentlich öfters mal.. die Leute haben keine wirklichen Probleme
BeitragVerfasst: 12 Jan 2011 11:04
+3!!
Du hast 3 Daumen??? :eins
Möchtest du drüber sprechen?
Felix
Dem kann ich mich nur anschließen. Alles Gute! :gut
BeitragVerfasst: 12 Jan 2011 11:13
Felix
Mensch Felix
Alles gute für deine Mutter und euch allen viel Kraft
In d haben wir seit einigen Jahren spezielle brustzentren
Gibts das in ch auch ?
